Neutral start switch 1983 15hp Evinrude
Kenerinn
The neutral start switch will not depress enough to allow the engine to start. If I hold it down with my finger or a screwdriver, it starts just fine. I do not see any adjustment for the switch other than a large nut. That has been tightened all the way. Any suggestions or do I just need to buy a new switch? Thanks.
The start switch and neutral switch are the same $$$$ part.-----You could switch them.-----Or simply bend adjust the bracket that mounts the neutral switch.----Easy I think.
