jonny rotten
- Jan 8, 2012
- 380
Sorry for all the questions,I want to get it right.I'm changing my gimbal bearing for the first time.I have a sealed bearing.Does the outside of the tolerance ring or between the ring and the bearing get grease?What about where the shaft goes through the center? The yellow dot is on the bearing but theres no hole .Does that need to align with anything?Cant see why it would matter.Should I clean the old grease out from where the bearing sits and grease it or bang it in dry? Why does the zerk have to come out and get plugged?No water is getting in through a zerk.The old bearing is out and new one in the freezer.Also whats the best way to hold the water passage o ring in place,vasoline, a little grease?
