Bt Doctur
- Aug 29, 2004
- 19,404
I was chasing a sometimes overflowing carb since last year. Rochester was original (89) so I figured it might need a rebuild. So in the meantime I replaced it with a Edelbrock that was used by a customer for 3 weeks until he got his back. No issues running . One day I could run the bay for 1-2 hours and get back to my slip ok, sometimes with a little black exaust smoke . Other time it would flood out almost immediately. So I rebuilt it again with a new needle and seat, and it still flooded out. Disgusted I went home for the night and pondered how a mechanical pump could ever increase its output pressure . Never had or seen it happen in over 55 years on any motor.
Rigged up a pressure gauge and low and behold 14 1/2 pounds of pressure . Could not believe it.
So if your have a carb overflow using a mechanical after you rebuilt or checked everything else
pop a guage on the pumps output , you just might fine your problem too
