Blindduck
- Apr 28, 2012
- 18
I have a 2009 50 hp 2 stroke elpto that keeps running out of fuel at trolling speeds. It will keep running if you pump the primer bulb which is empty when stalling. Seems to get worse as the engine warms up. The motor starts fine and runs great at high speeds. Can't seem to put my finger on this one.
I have replaced the tank which had a cracked pick up tube. Really thought that would be it. Since that I have rebuilt the fuel pump,new fuel filter, replaced the fuel lines and primer bulb. Still same thing. I also pulled the carbs off today and checked the bowls and seats which were all clean. This engine is well taken care of and is on the water at least every other weekend while either duck hunting or fishing. Neglect is not the case. Dealer can't find anything wrong but why does this keep happening? If anyone can help I would appreciate it. Thanks.
