Thirsty Endgrain
- May 30, 2020
- 250
Hi again, different engine this time. Just picked up an '84 90hp V4 that has been sitting for about 10 years, but looks to have not been used and abused. I couldn't properly do a compression test when I got it, didn't have muffs and I've read it's not good to even do a comp test without water running? Plus all of the wiring was disconnected, soooo. But was owned by a boat mechanic before it was stored, and it was an "it ran when it was stored" kind of thing. Time and detective work will tell. LU oil is oil colored, phew! Shift rod moves up and down, throttle moves nicely, plugs didn't look to be fouled up. Basically, as much as could be good without having it running in front of me was good, so I went for it.
It was $500.
Anyway, got it home and on the hastily thrown together stand. A few questions:
-It has tilt/trim thankfully, that looks to be in good condition. No bad corrosion around the cylinders. Unfortunately wires were cut willy nilly on this poor thing, and I'm not seeing an intuitive way to hook the tilt/trim switch back up. Hoping no major piece is missing. I'll include pics, maybe someone can point something out? I'd like to get this part working for ease of access to work on the thing on the stand.
-I want to start it obviously, but I want to make sure I do everything that should be done right beforehand. Bought a new impeller, and was going to install it before attempting to start it. Is that sound reasoning?
-Have new plugs, so I'll install those before attempting to start as well.
-Should I clean the carbs before starting? Assuming I should make sure the bowls are drained, though he said they were drained before storage.
-A friend said to run it with 50/50 mix/seafoam and let it sit for a couple of days. Is this sound practice?
-Was thinking to replace all of the fuel lines in the engine compartment before starting, to make sure there aren't cracked bits that end up in the carbs.
-I did just manage to get the ignition wires hooked back up to the point where i can push the key in to choke, and turn it to engage the starter. Finding the wiring color key was....key. Might have some questions on this once I dig deeper.
Pics to follow in next post, and fingers crossed.
It was $500.
