New Barr manifolds have loose chunks inside the water channels, L6, 165
ttownthomas
I'm replacing the manifolds and risers on my twin Mercruiser 165's (1972). I got the first manifold off and over to the bench and was getting ready to swap over the carburetor brackets. When I unboxed the new manifold I heard some rattling inside. I tuned it over and a chunk of loose cast iron (grey and rough looking) was sticking out the end. It is about half the size of a book of matches. I thought "this is not good" and looked inside the water channels with a flashlight. There appears to be a loose part deep in there too. So as a comparison I unboxed the other manifold and it has a rattle inside it too. I cant see any obvious holes or damage anywhere. What is normal here?
Lou C
They have a tech support line, call or email them I think they should take them back...
ttownthomas
Yes they do have a tech line which is close today and they have a tech line at the distributor I bought from. It is also closed today. I guess I’m just wondering if this is normal? If it is normal I will keep moving forward. I suspect it is not and I’m on to next weekend.
Levinz11
Replaced my 4.3 dry joint manifolds and risers last month with new Barr stuff. Mine had small fingernail sized chips of metal rattling around inside. I was able to shake most of it out. One chunk is still in there despite my best efforts. I was kinda bummed but no problems yet.
ttownthomas
They Said it’s not uncommon to have a few small pieces to get dislodged during shipping. Those pieces are a byproduct of the casting process. But the large piece that I was talking about is an usual and they replaced the manifold
