carlosburitica
- Aug 12, 2010
- 24
sounds odd but one of my batteries went bad so i decied to purchase to new ones, intellad them and went fishing....
started the engines nice and after 30 minutes in my first stop with engine off i see smoke coming out of the engine, literaly about to get on fire, so had to use my fire extinguisher for the first time in my life,.... well some how the regulator or the plug that connects the yellow wires to the stator where melted like if they were hit by a lightning.
inspected all the cables, replaced the regulator... fire the engine again and it worked fine for about 10 minutes until it started to run on limp mode, and tried to shut down the engine and it didn't die, removed the safety key pin and still running, tunrned the battery switch to off and still running, disconnected the batteries ans still running so i had to disconnect the plugs cables until it finally stalled... there after it did not want to turn on again, plugs got fouled... well i know this happens when it start to run in limp mode.... didnt check the power pack yet but it was replaced about 6 months ago...
clues here....
sounds to my like and electrical problem... but want to know a possible cause for it... new battery????? to many amps????
i am clueless with this one
clues here....
