Re: New boat, doing a wiring over haul, starter question
Lets see if I can add some value?<br />The starting circuit all are about the same main cable going into the solenoid from the battery.<br />There should be two bigger connectors (terminal) for power supply back to the key switched starting and charging systems and one to supply the starter. In most marine applications the power is supplied directly from the battery for onboard systems. This terminal will also most likely be used in your case to route the charge from the alt to the battery. You should find a small term 12-14 Gauge this will be the trigger for the solenoid depending on model there may be two small terminals one will be trigger and the other will supply current to systems that require it during the start process On the single terminal type there should be two wires one from the starter switch and one running to the plus side of the coil, this supplies the Ignition current needed to spark the sparks. Since, if you have a key switch the start is different then run. So when starting there is no power supplied from the key run position, only the from the start position.<br />When the key is released it switches over to the run circuit.<br />Back to the Starter when the start circuit is active the current runs down to the small terminal on the solenoid which activates the internal switch. The started draws a lot of current this is why you cant just put it directly to the starter. <br />But there are two main types of starters some use an external solenoid some have them built on.<br />The first type the solenoid is usually mounted in an easy access location relative to the battery and starter. When the trigger is powered it engages an internal high amp switch. When power is supplied to the starter it starts spinning which is designed to throw the gear forward into the flywheel as it starts spinning<br />The second type actually has two circuits, one triggers a plunger type system to pull the gear forward into the flywheel the plunger when it reaches the end of the travel in its bore it acts as, a second switch to transfer the required current to the starter for turning over the engine. <br />I know that not all are exactly the same but this is how mine works I have the second type as well and most I have seen in the older and auto market have been the same with a few slight differences in circuit paths but all worked on these basics<br />Besides if I have made a mistake Im sure Ill be corrected in short order.<br /><br />But in any case I hope it helps.<br />Alex
