new boat no worky L drive HELP!!
peacekeeper6
well the Ldrive force 125. i have everything done right but i am not getting any spart at all at the plugs. i have a spark plug tester with the light and on every cylinder it doesnt light up. what gives? i know newer boats havet aht shift thingy could that be whats wrong? i can get pictures if anyone needs. i was told to poist here as this engine is more of a outboard then inboard
roscoe
Re: new boat no worky L drive HELP!!
shift thingy ?<br /><br />Is the kill switch enabled?<br />Are you in neutral?<br /><br />If so, bypass the kill switch, check operation of neutral interlock switch if you have one.<br />Then check stator, trigger, switchbox, then coils.
eurolarva
Do you have the spark plug tester grounded?
peacekeeper6
how do i check those things? the cd's were replaced about 7 months ago, its inline
peacekeeper6
what am i checking on all those things? how do i check them? i was told this boat is operational so i would really liek to know what i can do to get it working. maybe i just have something aligned wrong or something somone please help!
peacekeeper6
and like i said all i ahve is no spark, i am new to this type of newer ignition so i would like to get the down and dirty on all the new terms. any help is appreciated.
roscoe
Check the back side of the ignition switch for any loose wires.<br /><br />The other things to check out on the ignition will vary with your model of motor. I don't have any specs for your motor, but they are available in most generic repair manuals, or in the oem factory repair manual.<br /><br />Doubtful that all coils would go bad so lets count those out for now.<br /><br />Stator is tested for resistance (ohms), 2 yellow wires coming from under the flywheel, lower numbers are good, high numbers or infinity is bad.<br /><br />Flywheel has magnets glued to the underside.<br />It spins over the stator which is a series of wire coils and generates power, which it sends to the switchbox.<br /><br />The trigger also picks up a signal from the flywheel and sends a signal to the switchbox, telling it when to fire. The switchbox fires juice to the coils which feed the sparkplugs.<br /><br /><br />I hope this helps a little, best to get a manual.<br /><br />And thank you for your Service.
DHPMARINE
I'd start with the guy that said the boat was operational.<br /><br />DHP
peacekeeper6
yea beleive me i did, and boy did i let him have it. he said fix the trigger linkage and it works, ok i say i get ahold of some good ol JB fix it and no spark anywhere.
peacekeeper6
well i have it all put together with the lock out switch bypassed. are there any more lock outs that i ahve to worry about? and the stator has some resistance but not that mch, i think around 3 megohms
peacekeeper6
and on the ignition side the boat lights up and everything works. . . but the engine.
