Re: new boat owner oil looks milky boat runs but almost dead? Is this a sign the
It's hard to say, without seeing it. If the oil in the crankcase (block) is milky, you have a leak.<br /><br />Most likely candidate is the exhaust manifold/riser. They can be checked.<br /><br />The oil in the lower unit needs to be changed, if it is milky. Worst case scenario, the lower unit needs to be resealed.<br /><br />Best case, the fill/drain plug seals are gone-easy fix.
