I recently purchased a 2006 Regal 1900. The current prop on the boat is a 17 pitch 3 blade. From the owners manual I should be around 4800 RPM's WOT. With trim all the way down and 2 people in the boat I'm only getting 4000 maximum RPM's. If I trim up to just under half way (on the trim gauge) my RPM's go up to just under 4500. So my first question is with a 17 pitch propeller do those numbers seem right? I would think that I should be more around 4500 when trim is down. As a side note I'm only getting about 38 MPH top speed which also seems low (increasing to about 42 when trimmed up slightly). From the specs on the boat it seems I should be closer to 50 MPH.
Since this is a new boat I'm just trying to get a baseline of what I can expect. The boat seems to perform well with only a couple people on board, but when loaded with 7 or 8 people it seems pretty slow getting up on plane. Takes about 20-25 seconds to get up to 20 mph before it starts accelerating quicker. I'm mostly concerned with performance for water sports and want to get the best hole shot I can. Am thinking of switching to a 4 blade prop, but was hoping to verify that the current numbers seemed correct.
Some additional information:
4.3 L 190 HP Volvo GX Engine
Volvo Penta SX drive (1.66 Gear Ratio)
15x17 Aluminum Prop
2006 Regal 1900 (19' 9") 2,800 lbs
Thanks for any information.
15x17 Aluminum Prop
