Re: new boater info
You can buy all the books on the shelves and you won't learn enough to buy a boat knowledgeably by yourself. You will learn a lot terminology, parts, construction, etc. But you definitely should get a pro to check out any hoat you are considering.<br />The pro should be able to do the following:<br />Check the hull with a moisture meter.<br />Thoroughly check the engine and outdrive (if you have one).<br />Check the electrical connections throughout.<br />Run the boat at slow and high speeds.<br />Make sure you have all the required safety equipment. i.e., Make sure you'll pass Coast Guard requirements.<br />Check the trailer. Brakes, wiring, tires, hitch, etc.<br />...... Heck this list could go on and on.<br />The point is you need someone qualified to look for any major problems or signs of problems that might arise. Someone who will do that for around $200.<br />That expenditure could save you thousands in the long run.......<br />Good luck.
