I have an '89 Johnson 25 that I recently purchased...first boat..and I have a few questions that I hope this forum can help me with.<br /><br />1.Motor does not want to idle. It will knock off after a few seconds of idling or most of the time when put into gear. I am a rookie and I noticed the gas vent was closed when I was loading up to leave the lake. Can that cause the idle trouble? Ran great from quarter throttle on. How do you adjust the idle on these motors?<br /><br />2. What is the red switch for on the primer? Which way is open or off?<br /><br />3. What is the switch for below the key switch on the shifter/throttle control?<br /><br />4. Is there suppose to be any type of air cleaner on the carb?<br /><br />Thanks for the help!
