thenotsofreeboat
- Apr 20, 2007
- 80
Hello Iboat peoples.
After haunting this website for months i decided that i need to join this group.
I have a free hurricane sportsdecker that needed/needs alot of work and have some questions I couldn't find elsewhere in the posts. The boat i have put in a new bildge pump, put in a fuse box and some new wiring(it had no fuses or anything before yikes) and checked for shorts. I won't do anything else until i actually run the boat in the lake. It has a crack about the size of a hair on the transom on one side but all attepts to move the transom or make the crack bigger don't work, so i think it is just a surface crack. At this point the boat is not so free anymore and don't want to spend anymore on a boat that may not run.
I have a 1981 75HP chrysler 756h1g it was last ran before i got my hands on it in 03. Since then i have replaced the lower unit and water impeller. I started it up in the tank and it idles pretty well after new fuel line and bulb. It is a smoking SOB but i have my fuel mixed with more oil to compensate for the long down time. Compression is 150, 150, and 145. Is there anything about this motor that i should be aware of?
I just got it reg. with the state and plan on taking it out this weekend or next. What should i look for in term of it actually working in the lake? I have read enough to know that if it runs in your drive way that is not an indication that it will work in the water.
Is there anything else that i need to do before i put this disater in the water other then bring along rope, a sign that says need a tow, a fire extingisher, life jackets and paddles?
Thanks i know this is pretty general but i would like to keep me and my wife safe and avoid the "i told you so nightmare" any negitive situation might bring about.
Thank you
Thank you
