New boatie question
andrewkafp
I am new to boating and have just bought a boat with 1985 merc with electric start no power TT.<br />Bought a workshop manual which tells me next to nothing about the merc controller.It has a "t" handle which when pushed all the way forward, unlocks the engine so it can be tilted. It also has a black lever along side. 2 questions 1. When in the water and running forward, when you push the T handle forward, what prevents the motor from unlocking in motion when you increase speed ?? And the other lever.. is that a choke ? or is it to be used in conjunction with the handle ? I'm sure there must be an explanation but there is NOTHING in the Clymer manual.
FlyBoyMark
Ensign
Re: New boatie question
The "other" lever is for engine warm up or "idle speed up" when the engine Is NOT in gear. When this lever is up you CANNOT put he engine into gear because of an interlock. Choking the engine is accomplished by pushing the key IN MOMENTARILY while cranking. DO NOT push the key in continuesly or you will flood the engine.<br /><br />I don't quite understand what you mean about the engine "unlocking in motion". It's supposed to do this in case you hit something submerged so that the engine kicks up instead of breaking the transom off... :cool:
JasonJ
Like Flyboy said, the outboard is supposed to be unlocked in forward gear only so the motor will kick up when striking a submerged object. The force of the propeller providing forward motion keeps the motor in place. The motor locks when in neutral, and in reverse as well. This way the motor stays put while backing. You definatly know when it isn't locked in reverse, because the prop will pull itself out of the water. <br /><br />Generally you don't need the warmup lever, but if you use it, raise it about half way. I start my Merc by never using the warmup lever. I prime the bulb, then turn the key to crank the motor. While cranking, I push the key in to activate the choke. Sometimes the motor starts and stalls, but usually as soon as it starts I release the choke, and if the motor starts to bog, I'll push the choke in again. The rpms climb back up so I release the choke. This is usually sufficient, the motor idles fine. If I am the only one at the ramp, I'll then pull my truck/trailer up and park it. Rule of thumb: Start the boat and make sure it runs BEFORE you pull the rig out. By the time you have parked the rig, your motor has ran long enough so you can pull out and cruise away. If there are a lot of people or kids around and I am alone, I start it, make sure it runs good, then shut it off while parking the rig. I have very little faith in people, I could see some moron walking by and throwing my shifter into gear while I am away, or an uncontrolled brat jumping in and doing something stupid. Good luck...
andrewkafp
Thanks for your replies..<br /><br />We have Australian boating sites, but when you have a USA made product, best ask the people that own and use more of them. I notice that you guys still take pride in older motors and tend to have the mechanical knowledge and enthusiasm the work on them. We tend more to go out and buy a new one rather than get involved in learning how the old models work. This is great if you have a large budget, but I don't... This site seems to have a goldmine of advice and info that can't be found in any book..
