New control panel installation
dwb693
:confused:Ok,
I bought an older pontoon for a project this spring. It is a running boat but is electrical nightmare. Sooooo I decided to replace control panel. I stripped all the wiring down to basics and just want Nav lights, anchor light and radio for now. There are no other accessories yet.
I now have new control panel installed and all switches are good (switches light up when in ON position anyway), however, I have NO POWER to any connections. Any suggestions out there??
NYBo
Re: New control panel installation
Control panel? Are you referring to a fuse block or do you have a switch panel with circuit breakers? What are you using for the battery negative connections to the accessories?
Im not sure if a new control panel would come with fuses already installed as fuses are sized to the load and that's something you calculate when you install the panel so my first question would be.....If the panel had fuse holders are there fuses in them.
