Have a 1978 Evinrude 85HP (model 85899C) that I’ve been working on. Runs like a new engine, however I can’t get the tachometer to work correctly.
The boat (1978 Ray Craft V150) originally had an Aqua Meter two-wire tachometer which was in disrepair (physically broken). Replaced it with a generic digital tachometer (Geloo 85mm 6000 rpm on Amazon) but got no reading whatsoever. That, coupled with a battery that didn’t seem to get charged, led me to replace the rectifier.
After replacing the rectifier there is some activity on the tachometer but it isn’t at all accurate - upon initial start-up the needle will jump to 2,000 rpm, then a second later to 3,000 rpm, then a few seconds later it’ll peg at 6,000 rpm and remain there until the engine is shut off. During operation the needle is steady - no jumping or bouncing to indicated a loose connection somewhere.
There is good continuity between the gray signal wire at the tachometer and where it screws onto the terminal block by the rectifier. There is also good continuity between the ground at the tach and the battery. The instructions for the tach I bought aren’t the best, but I believe I have poles set correctly (they list a 6-pole outboard to be set at “3” via the digital readout of the tachometer, which is where I have it set). I also tried setting the tach to “6” via the readout but there was no change in behavior.
Does anyone have guidance of where to go from this point? The stator physically appears fine (no black tar-type gunk around it).
Thanks in advance!
Evan
Thanks in advance!
Evan
