New engine rpm etc
mtnrat
Well i have 16.5 hrs on the 350 i installed in my 1981 18 footer with a volvo 280 leg.
I have 2 props.
The first is a 14x21 and runs 30mph at 3000rpm with a WOT of 44mph at 4200rpm.
The second is a 14x23 and runs 34mph at 3000rpm with a WOT speed of 47mph at 3900rpm.
This was done at an elevation of 3000 feet and 80F.
I think I should be getting more RPM out of those props with such a little boat.
It seems as the speed increases the bow begins to plow a little. The boat has trim tabs but no trim on the leg.
How do I get more rpm?
Timing?
Trim? - Would mean a different upper on the leg.
Here is a pic of the boat. I emailed the manufacturer and the weight including a SBC is about 2400lbs
Mahoney
Re: New engine rpm etc
I would first check all the plugs and make sure they are all firing. Those V8's will run on 7 cyclinders and you may never know it short of loosing RPM's. You may also have a couple plug wires switched.
I had this problem as well, and replaced the plug that wasnt firing only to discover later it was switched with another cylinder, doh!
those speeds relative to your RPM's sound pretty good to me aside from the lack of top end, so efficiency wise/trim sounds like that might be fine. But just in case, I would post a couple pics of the drive in the full down position on the trailer.
Mahoney
Whoah, also I just noticed you only have 16 hours on the 350 in there. Is it pulled from another boat I hope? You shouldnt be running that thing full throttle if its new or remanufactured till you go through the break in period.
mtnrat
I pretty much followed this break in proceedure and have not had WOT for more than 30-45 sec. I also changed the oil and filter at 10 hours.
Marine Engine Break-in Period
The first 20 hours of operation is the engine break-in period. During this period, it is extremely important that the engine is operated as outlined in the following information;
If the engine has an accessible oil pump drive, it is recommended that the oil pump be driven with an outside source for approximately 10 minutes. This allows all points lubrication before the engine is started and substantially reduces the chance of dry start problems.
Before starting a new engine, base (static) ignition timing must be correctly set and the carburetor primed with fuel. Excessive cranking of the engine to bring fuel to the carburetor or playing with the distributor on an out of time engine must be avoided. This excessive cranking will place excessive load/wear on internal components due to insufficient oil supply and lead to premature failure of components.
1. Upon engine firing, the RPM must be taken to 2000 for 20-30 minutes to properly break-in the camshaft. Failure to do so can lead to premature failure of the camshaft and lifters. During this period DO NOT drop to idle to check ignition timing. As long as the engine runs without labouring you can complete the cam break-in period. If the exhaust is too hot advance timing slightly.
2. After camshaft break-in, it is recommended that oil add filter be changed and the balance of the break-in period be completed.
3. DO NOT operate engine below 1500 RPM for extended periods of time during the first 1O hours. During this period, shift into gear as soon as possible after starting engine and advance throttle so that RPM is above 1500 (provided that conditions permit safe operation at this speed)
4. DO NOT operate at any one constant speed for extended periods of time.
5. DO NOT exceed ¾ of full throttle during the first 10 hours of operation. During the next 10 hours, occasional operation at full throttle (5 minutes at-a-time maximum) is permissible.
6. AVOID full throttle operation from stopped position.
7. DO NOT operate at full throttle until the engine reaches normal operating temperature.
8. OBSERVE INSTRUMENTATION carefully. If an abnormal reading occurs, stop the engine immediately and determine cause.
9. FREQUENTLY CHECK oil-level and add oil if necessary. It is normal for oil consumption to be somewhat high during the break-in period.
10. At the end of 20-hour break-in period drain break-in oil from crankcase and replace filter.
Recommended oil is listed in the manufacturers, operator’s manual. Oils in the 20-50 series are not recommended for break-in. Oils should be of SE/SF or higher API rating.
NOTE: In I/O (sterndrive) applications, the drive MUST be checked for alignment to prevent premature engine bearing failure due to side loading.
I will post pics of the drive fully down.
Thanks
mtnrat
Mahoney, Pics of drive. The boat is nose down with trailer tongue on ground.
mtnrat
Ok, Checked the firing order and it is correct 1-8-4-3-6-5-7-2. I took pics of all the plugs. They all look ok except #7 might be a little rich? Have a look see and tell me what you all think. The pics are in firing order.
Thanks
mtnrat
oops here they are. I hope. In firing order 1-8-4-3-6-5-7-2.
