new foam
BigDaddy9
Where can i go to get new foam for the boat that My Middle Son and I are restoring? It is a 1987 Spectrum.
Lion hunter
Re: new foam
Most people are using blue or pink sheet foam from home depot or lowes.
Jim Haswell
Re: new foam
I read on another forum they were using the long foam nuddle floats that kids are using in pools.
JaSla74
Re: new foam
Google 2 part pour foam & you should have no problems finding it. I know Jamestown Distributors carries it. You can also go with closed cell block foam. It's a bit more tedious to install, but won't absorb water over time.
BigDaddy9
Re: new foam
Can I use some type of spray foam? because it is an aluminum boat and wiell the same for floors.
Lion hunter
Re: new foam
I think once you remove the pourable foam thats in there you will not want to ever see or use it again. From researching the restorstions on here I think the blue or pink foam is the way to go. Not being familiar with fiberglass boats I would be curious how much structure the foam provides. You may have to use a pourable foam.
