Oshkosh1
Ensign
- Jun 8, 2009
- 968
So...Here's what I've done to winterize my engine.
1. Drained the block/manifold
2. Removed thermostat/thermostat cover/hose to manifold
3. Used compressed air to "blow" out the following: Block(through thermostat housing), Manifold(through opening from removing the hose), and Coolant water intake(through intake hose running from transom/stern drive).
4. Used about 1/2 gallon of "red" anti-freeze and poured through block/manifold/water intake...until I "flushed" them.
5. Closed/replaced drain plugs
6. Filled block/manifold with -50 propylene glycol anti-freeze.
7. Left the thermostat/cover/hose to manifold off to account for any possible expansion(we see -20 here).
8. Changed oil/filter
9. Drained fuel system/tank
10. Gave all linkages a good coating of oil.
11. Replaced V-belt
12. Checked/tightened all hose clamps. I added a clamp to every fuel line connection(seperator, pump) just so I have "back-up"
As for the outdrive...thats been removed/split and each half is clamped to a B&D Workmate table to store for winter/replace impeller/grease u-joints. Battery is in the basement.
My reasoning for using anti-freeze is to compensate for the heating and cooling of damp fall/spring conditions and as corrosion/scaling protection.
In the spring I plan on draining the block and manifold, capturing the AF and PROPERLY disposing of it prior to getting the hull wet. I plan on checking the valve lash(already have a new rubber gasket).
Right, wrong or indifferent...that's how I did it. Took me about 2 hours total from start to finish.
Any glaring errors/omissions/advice? Thanks.
11. Replaced V-belt
