new fuel bulb & line.. won't pump-up
showme219
First off, the bulb IS installed in the proper direction !! lol The old line and bulb didn't pump-up either. When I got the motor it had clear lines from the tank to the engine-mounted fuel pump. When I squeezed the bulb, gas traveled toward the fuel pump. When I let off the bulb, the fuel ran back down the line toward the tank. With the glass bowl on the bottom of the pump, I could tell that eventially it would fill.<br />The motor has a real lack of power at mid-top end, I am trying to determine if the fuel pump could be the culprit ?? How can I test it ? It pumps gas when I disconnect the hose.<br /><br />Any advice ?????
Dhadley
Re: new fuel bulb & line.. won't pump-up
As far as the bulb is concerned, it sounds as if you got an inexpensive type that has no check valves in it. They can be difficult.<br /><br />Good luck!
RICKRICK1
Ensign
Dhadley is right on, had this same problem went to a better quality bulb, problem solved.
silverking
I agree with them,<br />I just replaced the old inexpensive "generic" bulb for a new "Quicksilver" original replacement<br />Also you can check your motor fuel pump: unscrew it and check the gaskets and diaphragm, look for hole or leaks.<br />You can buy a new bulb and gaskets & diaphragm for less than $20.00 and do it yourself.<br />Good Luck :)
