New Fuel Pump or what???
NavyChief
Hey gentleman, hope you all had a great veterans day weekend. So here it is: I have a 20' grady powered by a 2000 Johnson 225hp ocean pro. Recently I towed my boat from North Carolina to New York, where I'm now stationed. I took the boat out in the bay fishing. After running the boat for about 2 hours, the engine would cut out if i tried to go faster than idle speed(5mph) or so. It also idles low and cuts out when idling in neutral(which i believe is another issues for another time).
So far this is what I've done: I was thinking there was a fuel restriction somewhere so a replace d the water/fuel seperator filter, the primer bulb and hose, and the filter inside the engine cover. Nothing... still cut s out. So i hooked up a 6 gallon tank and it was still cutting out. I just ordered my service manual so im ready to replace the fuel pump if need be. Any other ideas?
Chris1956
Re: New Fuel Pump or what???
Try pumping the fuel line primer bulb a bit when trying to accelerate. I will predict that it will have no effect. However, if the motor does run better, it may be a fuel pump, but since the fuel pump is a $400+ items, I would recommend you check some other things.
Check compression, check spark to all plugs. Post back. If these items check out, the carbs may be dirty....
NavyChief
Getting compression checked and going to replace spark plugs. Ill let you know, thanks...
