New Fuel pump
dmwelch
Hey guys,
I need some suggestion for cheap fuel pump alternatives. I have Johnson '68 RKL 30A with original fuel pump that I was told they don't make rebuild kits for so I want to just get a new/used fuel pump. Its powered by a hole in the bypass cover.
Does anyone have any suggestion of pumps?
Thanks
David
F_R
I am reasonably sure that 18-7820 kit will work. There may be a difference in a gasket or something that you can deal with. Otherwise, 18-7351 (3/16" hose to carb) or 18-7352 (1/4" hose to carb) fuel pump. You will have to re-route the hoses.
About the only thing that goes wrong is the diaphragm.---Can't find one ?----Then cut one from say the diaphragm for a 1966 model 100 hp.
dmwelch
Thanks just ordered one of amazon after digging a little more! Hope this helps others
