Re: New Fuel Tank
The boat is 25'long. It too has a closed bow, sleeps 2, some underseat storage and a small porta potty.<br />The deck space is open and seats 6.<br />The original tank was mounted in the belly, in front of the engine compartment and was about 90 gal, we calculated. The tank opening is 24.5" wide X 102" long X 11.5" tall (side height) at the front tapering to 8.5" tall (side height) at the back. The shape of the tank compartment is trapezoidal in cross section. The fill hose and vent line went out the starboard side at the front, under the deck then up the the side to the fittings. I believe there was also a drain tube from the front of the boat back to the engine compartment in the belly.<br />We started to smell gas and determined it was leaking so we cut it out. This was a long time ago so I don't remember how it was mounted, isolated from the boat hull, all the small details that I need to know now.<br />What is the ABYC standards book??<br />Thanks,<br />Jeff
