I am installing a new 3210, and the harness needs to be spliced ito the power chord, data port in, data port out. It will be in an overhead electronics box.
1- Does the antenna and the unit need their own separate power supply, or can I tie them both into a hot block on the fuse block in the electronics box?
2-What's the preferred way of binding two separate wires together? Wire nuts, tape, heat shrink, etc?
Thanks!
Thanks!
