New Gauges for a force 125
Thasme
I am looking for new gauges for my 1989 BluFin with a force 125. It currently does not have a tach but I would like to add one. Is this possible? I have been scouring for gauges and would like to have white face gauges with a speedometer (45MPH max), fuel, volts and tach. Any direction is appreciated!
64osby
You may want to consider a temp gauge also.
I have been looking a gauges to put on mine and the priority of importance. My priority list is Tach, Temp, fuel, volts and Speedo. On mine the fish finder will used for the speedometer.
In terms of specifics for tach and temp you may be better off getting this moved to the Force outboard section. They will be able to let you know the number of poles for your tach and if you have a temp sending unit built in or if it will have to added.
Thasme
I was curious about the temp as well. I have been browsing through the Force forums and also thought....dumb *** you should have put this on the force pages... going back to searching them now! Thanks!!!
