New Grease Seal Spring Popped out. Penta SX-M
rcollette
2005 Volvo SX-M 1.79
I just replaced the gimbal bearing and grease seal. While aligning the bearing, the spring on the grease seal popped off. Since everything is new I cannot take it apart and waiting to the next replacement could be a while.
Does anyone know how to put the spring back on? There is a little bit of space between the bearing and the seal to work in.
Since the bearing is now completely sealed, is the grease seal even very necessary? I can't imagine grease from the u-joint working up past the bearing.
Thank you.
Rich Collette, CT
2005 Campion Allante
RCSConstruction
It's a lot more common than people think. Some say don't even use it, some say install it backwards. You'll be fine.
