Hey guys, this is my first post to this forum, have been lurking for quite some time however... I am not new to the world of engines and I have an electrical background, i have owned and repaired a number of jetskis but have never owned a boat until this year. My wife and I bought a 1995 Javelin fis/ski with a 1995 Evinrude 130 on it. When i bought it I had the owner meet me at a dealership for a tech to run over it with me as it was -2* out at the time. He was able to fire it up for me and ran it for quite a bit to verify it ran alright. He also did a compression test on it with me (all showed 130 +/- a couple)
I recently was able to get it out on the water. The motor starts great, Idles great but only provides a strong hole shot some of the time. It seems pretty doggy most of the time out of the hole. Once in a while launching out of the hole it will pin you in the seat and then sort of fall on it's face. Once it is planned out and running "full speed" it seems to only hit 4200 rpm and as soon as i touch the trim the motor coughs and bogs down, shortly after recovers and picks back up.
I can't tell if the motor is only reaching 4200rpm due to the trim being too low in the water and putting more load on the prop, i can't test it too well as when i touch the trim it coughs... but i assume it will reach higher. just operating the throttle i can get it to reach nearly 6,000rpm. I also noted that when you would hit the trim button (any of the button locations caused this issue as well) that the tach needle would deflect slightly.
In the driveway last night i ran it and was watching my battery voltage. prior to start it was somthing like 12.8v, at an idle was fairly similar and slowly climbed with rpm. at around 3,000 rpm it was up to nearly 16v.
I have since dug into the rectifier as it seems to be an issue that comes up a lot. (side note the ignition was power pack was replaced last year by dealer) I did note that one of the legs of the rectifier was acting differently from the others. I probed it many ways with the diode test on my meter. Off hand i remember that two of the three legs had no reading either way when i probed the wire and the case of the rectifier, while the other leg provided a reading each way i believe...
Any insight from you guys would be greatly appreciated. I hate to just throw parts at it, but i do believe if the rectifier is bad and feel it needs replaced regardless, but i am unsure if that is the only issue at hand.
