new impeller but not pumping water
ril0
Have just fitted a new impeller to my Yamaha 175 v6 as after leaving engine over winter when I restarted I last week it would pump water one minute then next time would not .Took out old impeller expecting it to be damaged but nothing wrong with it .Fitted new impeller and same problem infact is now worse as will now only pump water if I use muffs and wont draw it from the tank .have tried putting hosepipe directly on riser pipe and water circulates out of pee hole at high pressure (mains water pressure) so assume engine is not blocked any ideas or should I have fitted pump repair kit and not just the impeller.
stylesabu
Master Chief Petty Officer
Re: new impeller but not pumping water
some engine don't work well on muffs. drop it into the water and try again
ril0
Thanks for the reply but have tried it in a tank of water and still no go read on here that some one had same problem which turned out to be the riser tube splt how do u remove riser tube seems like will need remove engine from leg big job if it shouldn't be split also if tube split surely water would not come from pee hole when hose connected to riser tube ?
