Re: new impeller installed- water output question
Matt Harper, welcome to iboats.<br /><br />In the future, click the "post new topic" when posting your problem/question. That will start a new thread, and you will get a better response to your question. <br /><br />yes that is a dangerous assuption. The motor is new to you, and you don't have any idea how old or in what condition the impeller is in.<br /><br />Looks can be deceiving. Replace it, then you will know, and should be able to count on it for 2-3 years.<br /><br />As for the drain plug, maybe someone replaced it with a non standard plug. Best to get it out, and replace it with the plug that belongs there. It gonna be impossible to fill with new lube the way it is anyway.<br /><br />With fresh gas and properly mixed oil, and properly adjusted carbs, your motor will smoke less. Clean out the gas tank and start fresh.<br />Using a full synthetic oil will help too. It helps alot on some motors.<br /><br />Probably time to do some maintenance like a decarb, also.
