130 HP JOhnson Motor was purchased new April 2002. Model # is J130PLSS and has 40 hrs running so far.<br /><br />Motor will not hold the RPM between 3100 & 3900 RPM. Push the throttle 1 notch up from 3100 and motor automatically goes to 3900 RPM. Push 1 notch down from 3900 and back to 3100. Speed difference is 23mph to 29mph. Motor operates properly at all other RPMS.<br /><br />Additional information. The prop is an SST 14.75 X 21. The motor is mounted on the bottom hole ie as high as it can go. Top RPM is 5,500 at 47 mph. Boat is a Doral Spirit, 17'4" and weighs approx 1,100 lbs.<br /><br />Thanks to All
