Hi,
I just installed a new light kit on a small trailer. I have a 4 prong connector. There are two tail lights, each has 2 bulbs. There are also two marker lights, one on each side. I have the wiring correct based on diagram and research on the interwebs. I have the white ground going to the trailer frame.
Here's my problem.
Marker running lights work fine.
Blinkers work fine.
Break lights work fine.
However, the rear running lights do not come on. But when I remove the large light bulb, the two filament bulb, the smaller bulb in the tail light comes on. As soon as I stick the big bulb back in, the little light goes out. The big bulb, the two filament bulb, never comes on except when breaks or blinker are on.
Quick note: when I remove the big bulb in the tail light and the little light comes on, it's not super bright. Although, this is my first light job so I guess that's relative to what my experience is with bulbs in general. I've also tried multiple big, two filament bulbs in the socket. I've also tried more than one fixture in the tail light position with the same results.
I though it might be a bad ground so I thoroughly cleaned the tail light mounts and ground wire mount. My truck is very well maintained and I keep the plug socket clean. I'm at a loss.
Thanks in advance.
Here's my problem.
Blinkers work fine.
Thanks in advance.
