New manifolds/risers seeping???
crazy charlie
I have twin 230hp mercruisers and decided to put new manifolds and risers one 1 motor this season and the other gets done next season.I replaced with Osco in May,used it all season with no problems.Upon winterizing this week I noticed a quarter inch rust ring at the riser manifold connection.I suspect a slight seepage.Am I tweeking the risers down or am I removing the risers and replacing the gaskets?????Charlie
scamper
Re: New manifolds/risers seeping???
Did you use anything like permatex when you first installed?
crazy charlie
No,just the gasket.I was going to use a tacking spray but i went without it.Charlie
scamper
On mine there is not much meat there so I use a little help. It usually works
