Hello ? I?m looking for some help getting my pontoon setup with the right propeller. It?s an 18? Bass Buggy with a new Suzuki 90Hp. The place that installed the motor put a 13.75 X 15 4 blade on it. The problem with this propeller is my RPM?s are limited to about 5600 and with weight on the boat the prop is either ventilating, cavitating or bouncing out of the water ? I?m not sure which. With only me on the boat it seems to do fine other than the limited rpm?s. (should be able to get to 6300)
I happened to have a Black Max 14 X 15 3 Blade that I tried. With this one I get too much RPM?s and the ventilating or cavitating is worse and happens with the throttle instead of when it?s bouncing around on the water. I can slowing ease into the throttle on this one and it seems to do ok ? other than the RPM?s would get too high.
A few things I was thinking about trying ? going back to a 4 blade and going to a 14 X 14. I was thinking a larger diameter to prop to fix the coming out of the water feeling (seemed better with the 14? that I tried), and dropping in pitch to get the rpms?s up. However, is going up in diameter going to counter the drop in pitch? If I go to a 14? should I drop the pitch more than 1 degree? Maybe a 14 x 12?
I?m open to any suggestions ? also thinking maybe the motor needs to drop down some.
Appreciate the opinions ? thank you!
