New old Fiberglass boat needs painted or gel coated
ab59
Ensign
I was going to wait until I moved before taking on another project but I could not help myself when this old river runner came up for sale fairly cheap. A 1971 19 ft Kenner FisinSki Barge or Bluffer that looks every bit her age. I wanted another Starcraft Aluminum to make a river boat out of but there just wan't one around so I bought the fiberglass ski barge . I live across from the Sacramento River so the need for a river boat . Someone already replaced the deck and the transom seems sound so a little cosmetic fiberglass repair and sanding and I will be ready to remove the outboard and center console and flip her over belly up for a new paint job. I was going to re gel coat the hull but I heard that the 2 stage paints are better and look good longer and I'm sure they have got to be easier to spray on than gel coat because of the set time of 10 minutes .
Aside from using some black 2 stage paint from a local Tractor place I have no knowledge of what paint is good or bad so I'm asking for you all's experience with the paints before I get froggy and shoot something on that isn't going to do a good job. Any experience with metal flake ?? thanks A.B.
Click image for larger version  Name:	DSC00324.JPG Views:	1 Size:	140.3 KB ID:	10898525Click image for larger version  Name:	DSC00328.JPG Views:	1 Size:	141.6 KB ID:	10898526
Click image for larger version  Name:	DSC00329.JPG Views:	1 Size:	144.3 KB ID:	10898527Click image for larger version  Name:	DSC00331.JPG Views:	1 Size:	141.4 KB ID:	10898528
ab59
Ensign
OK I found some threads about the urethane single stage paints that i will use But I am still unclear about whether or not I should use this paint below the water line on the hull . Is is safe to use this paint as Hull paint ???? Anyone ???
TBigLug
That's a bummer, I was hoping someone would chime in. I'm in a similar position of wanting to paint instead of regelcoat ny boat as well.
if the boat is a trailer queen and spends minimum time in the water, you can use it below the waterline.
I would spray gel myself.
Gel sprays easy if you use the duratec 904 gloss additive.
