Francin728
- Jun 13, 2011
- 27
I purchased a new oem mercruiser alpha I gen II drive. The previous outdrive shifted into and out of gear very easily. There is considerably more resistance in the shifter going into and out of gear. A couple of times is was stiff enough to kill the engine by sticking the shift interrupter switch. I have used the drive only once. Is this an issue of the drive needing to "break in" before the shifting becomes smoother? I had the shifter cable replaced roughly 6 months ago. That coupled with the fact that the previous drive shifted into and out of gear smoothly eliminates the shifter cable as an issue.
