firstimeowner
- Jul 10, 2005
- 6
Hello all, thank you for taking the time to assist me.<br /><br />I recently aquired a 1988 Sunbird Corsair open bow (I believe) with a 2.3 OMC Cobra outdrive and motor. It is using a SS 13.3875 17inch prop.<br /><br />I have two issues, hopefully they are related in nature as to not post too many questions on one post.<br /><br />1.The boat itself will run really nicely with 2-3 average size people aboard crusing at 20mph max. If I add anymore the boat will bog down and barely reach 11mph. I believe this is the design limitation of the boat as it rating is 6 people or 900 lbs, with gear 1200lbs. Anything over around 500 and I experience this problem.<br /><br />2. With only one person aboard the throttle and rpm's stop at 3/4, 3800 respectively. After this 3/4 postiion the engine will bog down and actually slow down in speed and rpm's.. It sounds starved or flooded, not sure how to tell. I have read in other posts that the rpms should be hovering around 5000 at WOT, which seems like it would if it weren't bogging down on me..<br /><br />I have never had it stall or die on me while in any thottle position however. <br /><br />I do have some mechanincal (auto) knowledge but have no clue on this.<br /><br />Thanks Again for any advice or input.<br /><br />Kevin
