hi, I recently bought a 1993 sweetwater 24 ft pontoon without an engine on it. I also recently bought a 2000 Johnson 70 hp and put on it. everything seemed fine with just me and my wife on it but when more people and more weight it really struggles and uses a lot of fuel. I did some research and found that the motor is supposed to be installed with the cavitation plate even with the boats transom. I didn't know this when installing the motor and put it down as far as it would go which is about 6 inches below the transom as the motor is a long shaft. what negative effects will there be having the motor this low? I plan on raising it up soon but just wanted to know what problems it would cause? thx, chris
