asignabove
- Feb 25, 2004
- 20
Just replaced the power-head on a 2001 Johnson 115hp Ocean Pro. I was following the break in procedures supplied with the motor. 1st hour I was to run the motor at no more than 3000rpm and vary the throttle setting. All went fine for the first hour. The second hour called for and increase in rpm to no more than 4000rpm and to vary the throttle. After about 10 minutes of running between 3500 & 4000 I brought the throttle back to 2000 and in the decrease heard knocking coming from the motor. I turned towards the dock and brought the motor up to 3000 and back down and the same knocking sound. The motor powered up fine and there was no knocking sound in the increase of rpms only when you slowed. I shut the motor down and coasted to the dock. I removed the plugs and the piston tops look fine, I used a dow to push on the pistons to see if rods were loose and there was no play. I premixed 50:1 in the fuel tank before starting along with the oil injection. I did notice a small chunk missing out of a blade on the prop after getting it home. Any Idea on what could be the culprit of the knocking(sounds like a rod knocking in a car motor)? There is a little play if you pull and push in on the prop. Could something in the lower unit have gone bad? Any ideas would be a big help.
