New problem!!!!!
badboy2003
Thanks for all the help.. I have finaly got it to turn over. The problem was the solenoid was wired backwords. Go figure. Now new problem!!! When I turn the key to the acssery position it turns over I don't even have to turn it to run. The solenoid is wired like this...... On the starter side large post is batt. orange, red w/ blue strip, and red wire going to the curciet switch. Next small terminal is purpple gose to positive on coil. Next small terminal is yellow w/ red strip and its the starter wire. Final large post front of engien is the lage yellow and ti go's to the starter. And it turns over the engien now. So why dose the key run in the acsessery position??????? I've replaced with new switch and it still dose it. Please help... I haven't drove it in 2 years now because of all the problems it has hade.... Thank you..:eek:
Re: New problem!!!!!
New problem!!!!!
Nope,... Same problem,+ this should be in the Same thread....
Your starter is Wired Wrong...
badboy2003
I don't understand how is the starter wiered wrong when there is only one wire to it?
