New prop, anything special I need to do?
paczowski123
As Per recommendations I just got my Solas amita 4 blade 19"x14.25 prop in the mail today. I am looking to maybe get it on tomorrow. Is there anything special so far as installation, tips, tricks etc. I would need to do? It come with a brass splined "washer" as I'd call it an a finned ring that I guess holds the piece in place and keeps it from spinning off? Will I just pull of my old prop and slide this one back on? I had read somewhere that the trim tab abode may new adjustment do y'all feel this will be necessary or even to replace it? I was not aware of this when I ordered the prop so I didn't think to ask if I needed an offset anode or any further parts etc?
paczowski123
Re: New prop, anything special I need to do?
I will now insert my foot into my mouth, since my boat has power steering and no finned anode. :)
Ayuh,..... Slather a good coating of Grease on the propshaft, 'fore ya put anything on....
jestor68
Did you order the Solas thrust washer with the prop?
paczowski123
Yeah I'll apply the grease for sure, no i did not order the washer. The man I spoke to said most use the existing one, I know not a good practice, but he didn't mention it needing it to work or being any different from the one in there?
paczowski123
Will there be a difference between the Solas washer and the current one? I am looking to install the prop today so any help would be appreciated greatly.
NovaNewfie
Just have a look at the two hubs. The washer "should" work. I don't know what your other prop was.
paczowski123
Yea I'm not sure of the manufacturer, but I will definitely be sure everything fits properly.
