Re: New prop for 1992 four winns 190 horizon with OMC 5.0
Read the stickys at the top of the prop forum and get us as much info as possible.
Usually prop size is under the prop nut.
Thanks for quick reply. Should have read the stickys first, sorry, first day in the forum.
1. More out of hole power (to pull big wakeboarders out of water with loaded boat)
2. Current Prop - Aluminium
3. Current Pitch & Diameter - Not sure. I realize this is important, it is the original factory prop, still looking online for info.
4. WOT rpm's - 4000-4200
5. 1992 OMC Cobra 5.0, 200 hp
6. 1992 fourwinns 190 horizon, 20ft, 2,750 pounds dry
As far as problem or issue trying to correct....never really had an issue with current performance of factory prop. Just time for a new one, prop is pretty chewed up (20 years old, only rebuilt once, and my sister starts a little too shallow when towing friends
) This summer with boat loaded with people, and extra 600 lbs of recently purchased sacs I want to make sure I can get 250lb buddies up out of the water.
Thanks again!!
