New prop hits outdrive trim tab
bear_69cuda
Gang,
My new prop hits this trim tab. I understand this tab is for non-power steering drives. I'm installing smart tabs. Do you think I'll be cool if I remove the tab? Boat, engine and prop specs below. When I ordered this, it said nothing of being for a PS only Alpha 1 drive.
This sucker has a big rake... Didn't notice till now. The prop has been in the basement since December.:eek:
Tail_Gunner
Re: New prop hits outdrive trim tab
http://www.iboats.com/Anode_Trim_Ta...0247244--**********.194624452--view_id.373281
Quicksilver Anode/Trim Kit
Part # 822777Q1
High-performance trim tab. - Mercury/Mariner 75-250 HP Alpha & Bravo I Sterndrives. 822777A1
boat1010
What pitch was the prop you took off? As far as removing the Tab that isn't a big deal. That is for keeping it going straight. You can get different shaped ones. I am assuming when you say the prop has a big rake you are talking about the pitch.
bear_69cuda
Sorry about my lack of termanology, pitch. :eek:... It's been some time since I was in the prop fourm... I took off the stock 14.25 x 21"P.... This prop is much more radical... Lot's of cupping also...
180shabah
Rake and pitch are two different elements of prop design.
Iboats has a decent "prop school"
Click on any of the propeller links at the top of the page, scroll down and on the right side is the propeller help guide.
kenmyfam
Hope it works well for you and you are not over propped. Please let us all know how it performs.
Good Luck and enjoy.
Tail_Gunner
It will be fine, i have had the same issue. The prop just has a high rake...is that a Stilletto or solas HR..;)
That node simply has had the fin pushed futher back..about a inch if i remeber correctly.
jerryjerry05
You can get a thinner tab from the Merc dealer.You should run it.It helps with steering. Jerry
nlain
My outdrive has no tab, it came that way from the factory.
lowkee
I don't think you should be running without that tab, as it is an anode (ie made to get eaten up.. so your outdrive isn't). You can replace it or just grind it down until it fits. You likely don't need that fin at all, as the entire piece is an anode, not just the fin.
nlain
Just to clarify, mine has no tab but has a tabless anode.
180shabah
Cuda, you definately want to get the offset tab. With a 3.0, you probably don't have power steering, the tab helps to offset prop torque.
Boats with power steering can use the flat plate instead of the tab.
