Re: New Prop
A 23 is a lot of prop for that size boat/motor combo. Most 19-20 footers I have seen usually carry something around a 14-14.5 by 21. My 190 came with a 14.5x21, and was spot on for RPM's and had good pulling power. I switched to a turning point prop same diameter, but 4 blade, and dropped a few RPM, but still in range. They have a calculator on their site that lets you enter lots of info about your ride to spit out a size/pitch recommendation. Just punching in a few of your specs, it is spitting out a 14.25x21 stainless 3 blade. Your pitch recommendation will also depend on manufacturer as well, 21 pitch of one manufacturer can perform quite different than another's, so I'd suggest looking at a couple brands and using their respective calculators for selection. More power and more speed is quite a challenge, you usually sacrifice one for the other. I will tell you, I tried Turning Points Hustler Aluminum 4 blade, and picked up a little hole shot, and 1or2 top end. However, if your RPM's at WOT are a bit low, switching to a lower pitch prop will increase your hole shot, raise your RPM's, and will most likely keep your top speed since you will be spinning that lower pitch a bit faster.
