Re: New Rebuilt 302 OMC fried after 30 min running.... They say warranty doesn't cove
Ok, just bought a brand new rebuilt 302 ford omc motor from a rebuild company. After getting the engine i put it in my boat. it started find and i took it out for a test drive. after about 30 min of running at about 3000 rpm's i hear a change inthe motor sound and then i look down and see the heat guage rising to 210. I immediatly shut it down and get it back to the dock. I call the company who gave me a 1 year unlimited hours warranty and they say to send the motor back to them. when they get the motor back they tell me that the heat tabs on the motor are still in tack but that the front two cylindars were over heated and scored the pistons. they tell me since i didn't have a thermostat in the motor that the cold water from my ENCLOSED COOLING system caused a reaction from the cylinders that were over heating. i told them that i may understand it if the water cooling the engine was fresh water from the outside but i had a closed cooling system.... they said it didn't matter....has ANYBODY ever heard such a thing or are they trying to get out of their warranty?
#1 unless i'm missing something " see the heat guage rising to 210 " in automotive that is not death yet .
#2 "the heat tabs on the motor are still in tack" Those are for their protection , if they didn't melt = no overheat sufficient to cause damage OR they put the tabs in the wrong place. Their choice
#3 "but that the front two cylindars were over heated and scored the pistons" is their something about this engine that the front cylinders get seperate cooling water? I DON'T THINK SO. In auto the rear cylinders usually suffer the damage first in my experience. The temp sender is at the front of all my 302 Ford engines and 210 might be time to shut down and check for a cooling problem but not a rebuild again.
If this were my engine i would get it back from the rebuilder A.S.A.P. don't let them touch it any further , make sure you get all your parts back. Take it to another machine shop have them mic the cylinders and pistons, an auto engine that runs in a hotter enviroment
experiencing this problem i would be checking for improper clearancing between the piston and cylinder.
The temp sender is just above those cylinders and 210 won't boil water but seems to have destroyed your engine, they haven't convinced me.Also check remaining cylinders for damage.
Sounds to me they don't want to honour warranty.
I also go with Bond-o /"So you installed a brand new motor, 'n didn't check out/ fix the cooling system,..??
Is the raw water impeller trashed,..??
'n Why were ya runnin' it Without a T-stat,..?? "
Thats just askin for trouble.
