I just picked up a 1990 175 Black Max. After hooking it up, noticed that I was not getting a tach reading and voltage was only on battery. Usual cuplrit is the rectifier. Changed that out and everything back up and working. But, after a few times starting it, problably no more that 15 mins running time over the last 3 days on mufflers, now my tach stopped again, and the battery is powering the motor. After checking the wiring diagram and reading up on the Merc manual, I followed the wires to the voltage regulator (yellow and red wires). Here I noticed only 1 screw securing the regulator to the block, and upon removing, found the contact surfaces dirty and corroded.
Could this be the problem with blowing a new rectifier? Since the contact surface is the ground, I'm thinking the regulator may have caused the problem. I metered the 2 yellow wires from the stator and they check out per manual specs.
