New regulator
joshdashnaw
So I got a new regulator and the new one has a couple extra wires. The old one one had the 2 yellows, 1 red and 1 gray. The new one has 2 yellow, 2 red, 1 gray, and 1 black. The two yellows are easy. I figured the greys go together. The black grounds to the engine and the two red both connect to the same red off the boat. Is that right?
Frank Acampora
Re: New regulator
Not familiar with the L drive but usually red is positive voltage and black is ground. Yellow is probably A/C from the stator and grey is probably tachometer--Check your wire loom under the dash. If grey is tachometer, it connects with either one of the yellow wires for signal. If it is a discreet separate wire on the regulator, then it connects to the termoinal labeled tach on the terminal board.
joshdashnaw
Re: New regulator
There are only for spots that the other regulator hooked up to and they were the same color. 2 yellow 1 red 1gray. Now I have an extra red and a black.
