shanz_2008
- May 19, 2010
- 62
Hi
I have two engines merc 4.3MPI 2007on my boat.
I just changed the risers of both engines and on one engine I was not sure that Imade the gasket lip in the right direction so after I stared the engine I took out the grabscrew that it is on the top of the riser and with a torchlight I checked the gasket and it was in the right direction lip facing up.
Wile I was doing the check, noticed that between the lip and the riser there was water so checked the other risers and found them the same. Then I took out one of the risers and confiremed that there was water and only the riser was wet,the extension and the manifold were dry,removed the plugs and there was no water inside.
Has any one encountered this problem because I can not understand from were the water is coming.
Is it possible that it is coming from the elbow that it is after the riser may be I installed somthing wrong?
