Worrad1956
- Sep 11, 2020
- 2
Hi i have recently purchased a 1978 celebrity with a 165 and a MC-1 out drive. I've been doing standard maintenance and have ran into a problem. I replaced all bellows, shift cable etc.
I removed the drive in forward gear as per the manual, replaced the shift cable and bellows, aligned the motor and put the drive back on. Now they say to measure 6 inches when the shift cable is fully pushed into gear.
Here lies the problem, when pushed in i cant back the brass barrel of enough to even get 6 inches (it bottoms out on the locking nut for the sleeve, as if its going to far) but i can get close so i set it and put it into place, then when i shift it will go into neutral but no reverse. and if i adjust it for reverse the problem is opposite. i feel as if it shouldn't be at maximum adjustment on a new cable. The foot is in the shift shaft and isn't to one side. is there adjustment for the shift shaft on the bell-housing? I saw there was two flat head screws on this and this is all i can think of that could be adjusted to maybe fix this? The old shift cable seemed to work fine before removal but i replaced for piece of mind.
Any info i would greatly appreciate
Liam.
Liam.
