This one is driving me nuts! Any help will be appreciated.
I have a 1998 Maxum 20' Bowrider with a 5.7liter Mercruiser engine and a Mercruiser Alpha 1 Gen 2 Outdrive.
The boat was getting sticky both shifting and using the throttle, so I decided to replace both cables. I'm pretty handy and found it to be a pretty straightforward job, except now that the new cables are installed, they're worse than the originals. After trying a bunch of stuff, I pulled the new cables back out and tried moving them manually. They're grinding...unless I twist the inner cable a little...SO...I reinstalled them and twisted the innner cable before attaching to the engine end. Here's what's wierd: After I twist it, it will work good for about 2-3 shifts, then it immediately starts grinding again and gets worse and worse with each shift.
I've really beat my head about this one. Can someone else give me some ideas? I bought the cables from a reputable local dealer, but maybe they're just bad cables. Are there any "premium" cables I can buy to make sure I don't have problems like this?
Thanks in advance.
Thanks in advance.
